trouble with skin builder
The directory is wrong and when I build the skin instead of going to the created materials folder in skin builder it goes to the temp folder and when I close daz3d they automatically get deleted. Every time I make it build skin it keeps giving me the same errors. Saying it cant find the file of the material it JUST created. For some reason skin builder is sending them somewhere and I have no idea where they are. I checked preferences and I dont see anything in the directory that sends them outside the daz library. They all load in the daz temp folder and disappear when im done.
Okay so I went into the skinbuilder and created a skin. At the very end of the dialogue boxes is a box called utilities. Under that tab is where you tell it to send your final textures.
it didn't work. It's still saying it cant find the texture and when I check the files they're still not showing up. They only go to the temp file and disappear
What file did you put to send the new skins too?
this is where you would put your file path for where you want your skins to be saved to. As you can see mine are saved to my F drive ( I have my content on a separate drive) insided of my content library files. I just added a folder inside my daz 3d library for the skins to be saved to. The one that says path for material presets is the one that has the skins in it. The top one is where the files are but are not where the actual skins are.
the created files folder in the skinbuilder folder. Where they usually went before the directory broke.
I've never used that folder, I've always used the utilities option. I send mine to the g8f materials folder.
