Fane by AprilYSH
garrett_3dgarrett_3d Posts: 20
Has anyone had issues using [Fane by AprilYSH] this G8 character? I have a character based on this preset who is pregnant. Using the bigger L and bigger R sliders to increase breast size is destroying the teeth.
Is this a known issue and is there a fix?
TIA.
  • felisfelis Posts: 6,137
    Where is the bigger brest morphs coming from?
    I assume it's a standard part of the Premier software? Just discovered it's done the same to another character but to a lesser degree.
    It was my assumption, that it are a bug with the motphs, and not the character.
    Please find the exact path to where they are.
    It should be reported to the one that has made them (anything sold in Daz store goes to Daz helpdisk9.
  • garrett_3dgarrett_3d Posts: 20
    Sorry for the late reply but I've not used that character since so I've not looked into it. I shall be using her again shortly though.
    I'm a bit of a tech dinosaur, could someone explain how to figure out how to map morphs down to a specific source file?
    Ah, found the problem after a bit of moochng around.
    The problem lies with the HR Physics Breasts morphs by Kaluma. I think I got the asset from RenderHub.
  • ElorElor Posts: 3,595
    It's possible that the morphs were not made or saved correctly and on top of moving the geometry around the breasts of your characters, they were also saved with information related to the teeth.
    The 'good' new is that since you bought it elsewhere, it should be a standard morph, so one we, as end users, can fix ourself.
    The first step is to check which vertices are moved by the morphs you identified as the source of your problem, then if either of these morphs were indeed saved with information related to the teeth, to remove the teeth from these morphs before saving them.
    The whole process is explained in these two videos:
    If you don't feel confident about fixing the problem yourself (I would at least try to see if the morphs are moving vertices around the teeth), another solution is to ask the creator of that product to fix it.
    It was a free product so I'm not too bothered. I've only a handful of renders to redo now I've changed the morphs so it's no biggie. I'll take a look at the videos though, interesting stuff.
