material room
How can I or can I import a jpeg in the material room? I have this pattern that I would love to use as wall paper for a wall.  How do I get it in the material room? Thank you to all who responses.
  • Richard HaseltineRichard Haseltine Posts: 109,139
    edited November 2015
    You need to select the wall surface from the drop-down list at the top of the Material Room editor. Now right-click in a blank area of the material editor and select New Node>2D textures>image_map. Drag from the pin at top-left of the Image Map node to the plug on the PoserSurface node labelled Diffuse Colour. Now in the Image Map node click the None next to Image_Source, click Browse in the dialogue box and pick your image. At base that should be it, though you may well want to adjust other settings on the PoserSurface to get the right look - and you will probably want to adjust the tiling setting in the Image map node.
