Timeline problem
I want to delete nodes in the timeline. When I attempt it, Daz freeze for 30 minutes before I kill it.
I tried 3DUniverse's Animation Stripper. It identifies 480 nodes to delete. It says "processing 1 of 480" and then 30 seconds later, the dialog closes. No keys were changed. No log entry.
What can I do here?
  • Richard HaseltineRichard Haseltine Posts: 109,125
    You want to delete items at a set time? That isn't supported. Or you want to remove keys from a node?
  • jmucchiellojmucchiello Posts: 848
    edited January 21
    It locks up if I try to delete these keys. I have never used 3DU Idle Animations since I bought it. And yet the keys are active in this DUF.
    This is the end of the LOG every time I kill it.
    2026-01-20 19:30:26.626 [WARNING] :: \src\sdksource\interface\widgets\dzmenu.cpp(408): Action class 'DzTimePaneSelectItemCurrentTimeKeysAction' not found in DzMenu::addAction()
    2026-01-20 19:30:26.626 [WARNING] :: \src\sdksource\interface\widgets\dzmenu.cpp(408): Action class 'DzTimePaneSelectAllCurrentTimeKeysAction' not found in DzMenu::addAction()
    2026-01-20 19:30:26.626 [WARNING] :: \src\sdksource\interface\widgets\dzmenu.cpp(408): Action class 'DzTimePaneDeselectItemCurrentTimeKeysAction' not found in DzMenu::addAction()
    I'm uninstalling 3DU Idle Animation to see if it gets cleared out of the DUF.
    EDIT: Moving things one at a time. It locked up attempting to "delete selected key(s)".
    1483 x 454 - 58K
    1418 x 83 - 6K
    Post edited by jmucchiello on
    Well, the simple solution was to save the DUF uncrompressed and empty the "animations" array in notepad++.
    "animations" : [
