Loading scene has something in it that isn't there...
leo04
I am getting a Missing File message that says it can't find ".../data/brian/Mallorie GF8/Mallroie GF8 Figure Prop Assets/Genesis8Female.dsf". The Mallorie figure is actually a Genesis 3F model.
Now at one point I did try to move it into a G8F but that failed and I am happy to just use the G3F but I keep getting the message everytime I load the model.
How do I get rid of this?
Thanks.
What is the full error text from the log, Help > Troubleshooting > View Log?
[ERROR] :: Open File Failed - Could not read file: /data/brian/Mallorie GF8/Mallroie GF8 Figure Prop Assets/Genesis8Female.dsf
Is it a scene or a character you are trying to load?
It seems to be connected to a character but it doesn't really exist...
It doesn't say could not find, it says could not read - that would mean the file is there but not, for some reason, readable (not the same, I think, as an internal error once it is open).
I thnk what has happened here is I tried to create a new character from a GF3 one into GF8.
The character failed to convert the way I wanted it to and so I deleted the files.
Now for some reason the database still sees this file and tries to load it, but can't find it.
I have a lot of 3rd party assets so I am reluctant to reset the database but not sure there is any other way to rid myself of the file.
Any ideas?
Thanks.
P.S. I search for and cannot find the file.
I suspect that when you tried to create your character you used "Figure/Prop assets" instead of "Modifier assets" to save it, as a result you created a second version of G8F, you have then used that copy in your scene instead of the original.
It's the only reason I can think of that can explain why your scene is looking for G8F's main asset file in the wrong location.
