problem with scene tab going walkabouts
Newbie Q. I am not sure what I did but for some reason the scene tab is not above the parameters tab where I normally have it. I can only acess the scene tab through the tab tolder icon. How can I add it back to being above the parameters selections please? thx.
  • "Tab folder icon"? You can right-click in an empty area of the tab well in the group you want it in (the area that has the tabs for the panes) and select it from the Add Pane option. You can also open it from the WIndow>Panes(Tabs) menu and, as long as Lock Docking/Undocking is not checked in the Window>Workspace manu, drag its tab into the pane group you want to add it to.
  • ToobisToobis Posts: 993
    I'm sorry I am not sure I follow you. Any chance you could screenshot what you mean? thankyou.
    Interestingly, it's disappeared on me recently as well - I'm using the Alpha though - so every time I load up Daz I have to re-dock the tab. I can't give you any better advice than has been offered, unfortunately, merely my sympathy.
  • Richard HaseltineRichard Haseltine Posts: 109,151
    edited January 1
    Here, for the simpler route.
    1920 x 1200 - 724K
