Does GenX not work anymore?
2»
  • I resorted to using it on my Win7 and copying the morphs over, I did find the AppData folders but copying them it still fails to show, maybe DIM has a Zip instead of an installer, it won't install, says it's incompatible
    will look later
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,516
    edited December 2025
    well, it is a zip and extracts
    I located the folders to copy paste to
    now 2 also appears in plugins but not the UI
    I do have both working now in D|S 4.11
    1255 x 314 - 47K
    1506 x 752 - 50K
  • NorthOf45NorthOf45 Posts: 5,744
    I believe Generation X needs to be uninstalled for Generation X2 to work. I had GenX and I remember when installing GenX2 that GenX had to be uninstalled. The GenX addons are still needed for Millennium Generation 3 figures, but not the plugin.
    I shall investigate this further tomorrow but at least I now know the zip downloads can be extracted and manually installed yes
    may be helpful to the OP
    all working now, indeed uninstalling GenX fixed Gen2
    I do know what happened
    my C drive stopped booting up a year ago so had to replace it and reinstall software
    not used GenX since
