How can I find my lost custom CMS sub-category? [Solved]
lukon100lukon100 Posts: 849
I moved my custom sub-category from one category to another by dragging-and-dropping.
A split second before I could take my finger off the mouse button, the CMS index jumped around, putting some other super-cetegory under my cursor, such that my sub-category ended up in some other super-category by mistake. But now I don't know what other super-category received my sub-category. I can't find it.
My sub-category is called "Shinwear", as in, stuff characters wear on their shins.
I type "shinwear" in the search thing and nothing shows up.
How do I really find it?
Post edited by lukon100 on
  • crosswindcrosswind Posts: 9,721
    You can try using advanced fiter > key , i.e. : go to Smart Content, Products tab or Files tab, type in "key::Shinwear into the filter field. You should be able to find the item categorized with Shinwear.
    Then open Categorize dialogue with the item selected, drill down into the categories that in white color. You should be able to locate it.
  • lukon100lukon100 Posts: 849
    Thanks, crosswind.
    That worked. My "Shinware" sub-category was in "Props/Musical".
