MY characters not render and are blocks in Daz Alpha
Hello:
I had Daz Alpha and I install different assets. Enviroments load perfect but when I try and click any character genesis 8 show some message (missing things) and at the end render the clothes or accesories but the character is A) invisible or B) a few blocks with no texture. Happen the same with any of the 20 different characters I had, then must be some issue in Alpha studio. Thanks
  • Posting the actual error messages would help, but it sounds very much as if the base figure and clothes are either not installed or the location to which they are installed is not correct. Was the cintent that does work installed in the same way as the content that does not work? How did you install?
