Half cropped image after render.
This has already happened to me a few times, and it's extremely annoying.
Sometimes something similar happens in the iray preview. Moving the camera fixes it.
I was using the ''direct to file'' option since it helps with render time. I guess using ''new window'' seems to be the only answer to this.
  • It doesn't really look likely, but have you checked that there is nothing that might be blocking the view - sometimes the calculations can be different due to the different division levels (by default) between render and drawstyle. Also check to see if you are looking through a gap in a model, if there are concave polygons (polygons with four or more vertices where the shape they form has an indent, such as a chevron) then that can get filled in and block the view.
