Morph Scaling Issue
3DIO3DIO Posts: 5
I'm having a morph scaling issue where my pipeline is as follows:
  • Export G9 from DS 4.24.0.3 at base resolution using the latest Daz To Blender bridge available in the DIM
  • Import G9 to Blender 4.3.2 using Daz To Blender bridge
  • Sculpt G9
  • Export G9 from Blender using the .obj exporter
  • Import G9 to DS using Morph Loader Pro
No matter what I do, the scale is off when imported back into DS.  I'm having to use a scale of 0.410 when exporting from Blender in order to get it to work.  There's still a very slight change in scale even at that setting, but there should be no change at all, and it's obvious that having to use a scale like that means that something is not right somewhere in the pipeline.
Since I have no idea what scale is used by Daz To Blender when exporting from DS or importing to Blender, I'm finding it impossible to locate the problem.  YouTube videos and forum searches haven't helped since I'm using Daz To Blender to export and Morph Loader Pro to import.
If there's anyone using the same pipeline, it would be appreciated if I could have the following information:
  • Scale used by Daz To Blender when exporting from DS
  • Scale used by Daz To Blender when importing to Blender
  • Scale to use when exporting via .obj from Blender
  • Scale to use when importing via Morph Loader Pro to DS
Post edited by 3DIO on
  • That sounds as if you are using the Poser preset in Morph Loader. OBJ has no inherent scale, so import and export make assumptions - use the same preset for export and import in DS, and 100% in Blender, and all should match up.
  • 3DIO3DIO Posts: 5
    I did try the Poser preset at one point, but only because what should have worked, for some reason wasn't working.  I must have been careless with my settings somewhere along the line.  I wasn't aware the .obj format had no inherent scale, so the Daz To Blender bridge not offering a Scale setting for export makes way more sense now!
    Thanks, and much appreciated.
  • The Poser preset is probably the problem, I would sugest using Modo or one of the other 1 unit = 1 m presets on import. But the point is to match the import and export presets (which will cancel their chnages out) while leaving the import into/export from Blender unchanged.
  • crosswindcrosswind Posts: 9,686
    edited December 2025
    DTB doesn't use OBJ format but FBX which has no scale options for both export / import in DS / Blender. So DTB always exports as 100% in DS, imports as 1 in Blender (by using FBX importer).
    So, if you use DTB for the sculpting workflow, you just need to export to OBJ in Blender with Scale 100.  Screen shot 1 is for export OBJ in Blender. Screen shot 2 is for import with MLP as default.
    Don't use Blender or whatever other Preset in MLP, just use Default.
    2202 x 1181 - 377K
    765 x 702 - 47K
    Post edited by crosswind on
  • 3DIO3DIO Posts: 5
    Sorry, Richard.  To be clear, I followed your suggestion and it works fine now.
    Thanks and much appreciated.
    Crosswind, all working now.  Pretty sure I used Default the first the around, but somehow managed to mess-up a setting without realising it.
  • 3DIO3DIO Posts: 5
    It appears Daz To Blender doesn't support Anatomical Elements morphs.
    That's a problem, because aliens for example can be quite different down there!  So I looked into Diffeomorphic, have the latest version installed and while I've not actually gotten anywhere with it yet, it does look very powerful so I'm hoping it supports Anatomical Elements.
    I've given it a try, and it failed in the same way Daz To Blender failed, in so far as the Anatomical Elements stretch and distort in a sort of arc rotating on the X axis.  Can someone please provide a link to a video,  tutorial, or perhaps give a step-by-step for getting G9 Anatomical Elements out of Daz Studio, into Blender via Diffeomorphic, doing the sculpt, and then bringing is back into Daz Studio successfully as a morph without distortion?
    Never had these problems back in the day, everything just worked but it all seems so complicated now.  I don't think I'd be allowed to show a screenshot of this problem, so I've chosen not to just in case.  But again, any help with this issue would be much appreciated.
    What's interesting is that in both cases, and regardless of whether using Daz To Blender or Diffeomorpic, using a method whereby only the geometry and no rig is used, you would think that method, at least, would guarantee success.  But it doesn't.  I'm puzzled why either should fail at all, especially when using an .obj files only workflow which I tried as a last resort to get it to work.
