DAZ Keeps Changing Window Size
Apologies if this has been answered elsewhere, but every search term I come up with results in huge quantities of false positives.
As I use DAZ, it keeps changing the window size when it has a complex operation.  I have a 4K screen, and I have font scaling set to 150% (Windows recommended value). I run DAZ in fullscreen mode, but during loading of props, or files, or any complex operation the window will reduce in size to 2/3, and it looks like the fonts are set at 100%.  Then it flashes back to full size.
It's incredibly distracting and annoying, so I am hoping this is a known issue and someone can suggest a fix.  I can't say which version this started in, but it was a few months ago.
  • May be a function of the Qt framework, does this also happen in the DS 2025 Alpha?
  • stgastga Posts: 27
    I'll give it a try.  Thanks for the idea.  It definitively didn't used to do this, and it's really disruptive of the work flow, as suddenly your whole workspace disappears for 10-20 seconds, then pops back.
    The problem seems to be gone in the 2025 (6.25) public build.
    Also... a bunch of other longstanding performance issues seem to be absent, like clearing the scene can take 5-10 mins, but seems to be reasonably fast in this build.
  • Having the same problem, load something in or run simulation and it makes it small for 1-30 seconds then resizes where it should be indecision
