KBXF Slow Motion Player [Final QA]
kabexef
When an animation is played in real time, you often only see individual frames and the animation appears to jump back and forth randomly. This is because the complete creation of a frame usually takes more time than is available at the selected playback rate.
The «Slow Motion Player» offers two additional options for playing your animation:
- Frame by Frame - In this mode, the «Slow Motion Player» gives each frame the time it needs to be fully created. This allows you to play your animation as quickly as possible without losing a frame.
- Slow Motion - In this mode, you can even determine the time available for creating a frame yourself.
All modes offer the options ‘Select playback range’ and ‘Looped / Play once’.
In ‘Frame by Frame‘ and ‘Slow Motion‘ modes, you also have the options ‘Forward/Backward’ and ‘Play Subframes’.
The playback bar, various displays and tooltips, as well as the option to save settings in the scene, round off the appearance and possibilities.
Post edited by kabexef on
Thank you very much for this. I was just getting into animation, and the regular timeline preview is all but useless; this will save me so many headaches it should come in a prescription bottle.
This sounds awesome. Any idea when it will be available? (I know I shouldn't ask.)
No estimated delivery date has been set yet, but I will get back to you when I know more.
The product is now in the final QA and is hopefully coming soon :-).
