I got the "G8F Better Nipple GeoGraft" but i dont know how to apply the material
These are the instructions."Simply select the G81F_BetterNipple object in the scene hierarchy and load the matching character's body material file." I folllowed those instructions but they are very vague, you select the object in the scene tab and not sure what i am suppose to do from there. I thought maybe i would find a solution in the surface tab but i didnt see anything that looked like it would give me a way to insert the default body material. What would be a way to fix it?
  • felisfelis Posts: 6,154
    I am not sure which product it is.
    But my assumption is that you must select the torso/body surface af the character in the surface tab and select copy, and then select the geograft in the scene tab, and the nipple surface in the surface tab, and paste the surface.
  • You may even be able to apply the character's Materials preset if the surface names match - the quoted instructions  sound that way.
    But are you using another add-on, such as anatomical elements, that uses a Geometry Shell? If so it won't be set to hide the geometry from the niple graft, and so you will end up with an opaque layer on top. The fix for that is select the shell for the other product and then it will, in the parameters pane, have a great long list of the surfaces and groups on the combined shell with On/Off switches - you just need to toggle its visibility off on the Better Nipples graft.
  • Ah! you need to clear the geoshell. Or use something like geoshell fix, omni fix. Select the shell after applying the mat, then use shell fix or such.
    most likey the surface is white? or semi white?
