Three More Wishes G8F
A collection of models that combine into a gossamer-skirted / billowy pantaloons outfit suitable for a si'la, a form of djinn from Arabic mythology, rigged in DAZ Studio for Genesis 8/8.1 Female, intended for use with dForce dynamic cloth simulation. The outfit consists of a bikini top and bottom, rigged separately as regular conformers; and attachments for the skirt, pantaloons, stole and shrug that are to be simulated as dForce dynamic cloth. Wearable presets are included to load the upper and lower parts of the outfit seprately or to simply load it all in one click. NB: This is an expansion/alternate version of my earlier Three Wishes outfit, and includes all the content from the prior release, overwrite contents as needed. Installation order does not matter.
Download: RenderHub (login required)
Download: Google Drive
Couldn't get PostImages to show it correctly, and I don't know of another image host that the UK allows through, although you can see the promo images in either of the download links before actually downloading.
e: figured out what the problem with Postimages was, let me know if UK readers can see the promo images please.
Gorgeous!! Thank you so very much!!!
People seem to really like this set, I'm glad it came out so well
Very nice! thank you!:)
I think this is my fave of your sets so far. The skirt, especially, has a lovely ethereal quality. Thank-you for sharing!
Is it intentional that the license on this set on RenderHub is set to “Extended Use License (IP Restricted)”? I’m not sure what intellectual property the set is using.
The general rule for anything I publish is no redistribution of contents, renders and other use are OK.
Dreamy set, especially that floaty skirt. Thanks for sharing!
(grantzero: Renderhub seems to list everything as IP restricted for a day or two until they've had the chance to check the item. If you look now, you'll probably find the IP restriction has already been removed.)
