Any way to automatically ignore load error?
When an error occurs (e.g. dupicate formula found) while studio is loading a scene or other asset, it stops and puts up a requester that I must dissmiss. Is there some easy way to have studio ignore load errors and continue without my having to to dismiss the requester?
I have searched for an answer but the ones I have found apparently refer to earlier versions of studio because their proposed answers are not possible (e.g. the solution refers to a menu or pane that does not exist). I am using studio 4.24.0.3 (64-bit) Public Build on a Windows 10 computer. If you know of an existing forum post with a solution to this, please feel free to point me to it. I did search but came up with hundreds of results the first few pages of which were not directly related to it.
Thank you in advance!
The inability to have these warnings / errors ignored automatically is very annoying. The worst is when using Man Friday's extremely useful Render Queue (one ofthe best DS plugins ever; thank you Man Friday!) I use it so that I do not have to pay close attention to long-duration renders. But now when it loads a new scene, the duplicate formula warning box comes up and waits for me to manually dissmiss it. That essentially obviates the utility of Render Queue. Surely there must be some way to have that warning dismissed automatically. I see no good reason why it should have to wait for me to do that manually.
BTW, this happens with every single G9 load -- even those of the base figure alone.
I am using DS 4.24 Public Build on a widows 10 computer.
There's no such a feature to disable these warning messages popping up in current build of DS ~~ but with Render Queue, the option of Suppress scene load errors didn't work for you ?
or you better first of all fix these duplicate formula errors ~~
See https://www.daz3d.com/forums/discussion/comment/9137816/#Comment_9137816 for some scripting options.
Just bear in mind that if there was a warning and you suppressed it, you will not then get the expected/correct behaviour from the item that prompted it.
Thank you, Crosswind and Richard, for responding to my question. In Render Queue, I do have the ignore load errors box checked. But it stops with a requester for duplicate formula found errors.
This error occurs for every G9 figure I load. Is there any way to fix it? It will, of course, show up in the log. But once I find it, is there any way to edit the offending files to keep it from happening? It is seriously annoying to find that a requester was waiting for my click for hours when I thought DS was rendering a complicated scene.
