fbx export animation not working not working
so, i went through everything google ai could through at me to get fbx exporter to work...nothing worked..what now?
  • You mean no file is produced at all, or it is failing in the destination application? What is the application you are trying to export for?
  • There are two sides of this, you have the export and then you have the import into some other application, both can cause problems so you really need to give a little more ifnormation of what it is that is not working.
    FBX is a very complex specification so it is difficult to make a generic export (or import) that work everywhere, so if you have a specific issue it may help tweaking one or more of the parameters in the export dialog.
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,005
    edited December 3
    there are actually a number of optional FBX exporters, one on GitHub and what I often use the DAZ to Unreal ecporter, the latter renames nodes fixing a duplicate issue the inbuilt FBX exporter often has
    depending on the target software some might be more suitable than the default
    I had another thought
    is it keyframes or an Aniblock
    the latter needs to be baked to keyframes
