(Released) LIE Skin Blends [Commercial]
Silas3DSilas3D Posts: 793
edited December 2025 in The Commons
Hi everyone!
My next product releasing soon is a collection of LIE skin presets for Genesis 8 and 9 figures. It enables you to create fantasy/alien versions of your favourite skins, all within Daz Studio!
Adding color directly to the Base Color and Translucency Color channels often results in a darker, muddier look with lost detail and contrast.
LIE Skin Blends uses the Layered Image Editor and its blend modes to add color layers to skin surfaces whilst maintaining saturation, luminosity, and enhancing detail and contrast.
This can also be used as a merchant resource since LIE generates updated temp textures with the new layers, which can then be saved out. Supports both Iray Uber and PBRSkin with unique results across different skins/shaders.
Layer presets include eight colors in four opacities, luminance presets for adjusting lightness or darkness, plus separated base and translucency presets for extra flexibility.
Store link: https://www.daz3d.com/lie-skin-blends
Additional Info
  • As an alternative to the luminance presets, if you have Josh Darling and I's 1-Click PBRSkin product (https://www.daz3d.com/1-click-pbrskin), you can use the gamma adjuster script after you've created your skin coloring to tweak the result.
  • Default anatomical elements are also supported, but you will need to select the graft as well as the figure in the Scene tab before applying a preset - this is because LIE presets aren't hierarchical.
  • Similarly, because Genesis 9's mouth is separate geometry, you will need to select it in the Scene tab if you want the color preset to apply to the tongue, mouth and gums (teeth will be unaffected).
  • These presets apply cumulatively, meaning that applying multiple presets one after the other will stack on top of each other, rather than remove the previously applied preset. This enables a high degree of skin customisation as you can apply multiple semi opaque colors or multiple luminace presets.
Thanks for your time :)
Silas3D
Post edited by Silas3D on
  • Silas3DSilas3D Posts: 793
    edited November 2025
    Here's another example - an interpretation of Elphaba, using Angela 9 as a base and some basic morph tweaks.
    Also using my Lip Service for Genesis 9 product for the lips
    1000 x 1300 - 1M
  • nonesuch00nonesuch00 Posts: 18,822
    Very nice, I look forward to it.
    @nonesuch00 thank you! By complete coincidence the Dragonscale LIE Textures Add-On that was just released uses the same method to tint the skin, however there's only a few colors with that, no ability to have different base and translucency colors and doesn't support anatomical elements. Whilst my product synergizes well with Dragonscale I've got some ideas for a Dragonscale expansion which will add even more options - I love it when new products inspire me :)
    I plan on getting that tooo, not I likes your color blends and choices better, thanks.
    Here's another example :)
    1000 x 1300 - 2M
