Thoughts on 'wear-them-all-autofitting-clones-and-clothing-smoothers-for-genesis-3-female-s'?
HorusRa
Just wondering what thoughts are for 'Wear them all' http://www.daz3d.com/wear-them-all-autofitting-clones-and-clothing-smoothers-for-genesis-3-female-s
Does it work very well? Is it worth purchasing? Any thoughts and views on this item are greatly appreciated.
Post edited by HorusRa on
If you're up for Genesis or V4 clothing on your G3Fs, then it works brilliantly unless you're dealing in long hair or skirts. If you want long skirts, you need the Ultra Templates Lady SickleYield made. Between the two, however, you can do nearly anything. The morphs for reducing shrinkwrap boobs aren't quite as nice as the ones in Fit Control for G2F, but with a little bit of smoothing they are, in fact, up to the job.
I bought both Wear Them All and the SY templates, and I have no major issues that aren't created by really baggy sleeves. They even tweaked the stock G2F clone a bit for better G3F fits. I'd like something for long hairstyles, but that's a minor thing compared to what was actually on offer.
11/10, would buy again.
Thanks Dark. I'm partial to long hair, so I do have a fair share of that for V4, and have a moderate amount of skirt style clothing for the same too, so I guess thats kind of a bummer. While it seems mostly for clothes, I did note the help it gives with hair and shoes, so I was kind of counting on the help with my V4 hairs, bu they are almost all long. I guess this will be something to think about. Thank you very much for the info, I appreciate it.
If you're planning to use any of your older content with G3F, trhen get it. If not, then don't. You'll save yourself a huge headache down the line. It would most impact hair that's rigged, as there wouldn't be new rigging to match G3F. Morphs for hair can be put back in if needed with the transfer utility.
For shoes, it works far better than it did earlier. Not necessarily perfect, but much closer than it was before, and it makes high heels far less of a nightmare.
For skirts, invest the tad bit more for the Ultra Templates, as I said. I got V4's MFD on G3F in good order, andif the templates can do that, then your'e pretty much all set.
As content converters go, Wear Them All affects the upper box in the autofit dialog, expanding things and making life simpler. Ultra Templates adds stuff to the lower box, and is outrstanding for skirts, loincloths, and all other manner of similar critter. Hair works either way, but you might want to transfer the original morphs back in before you save it as a figure/prop asset.
The question you have to ask yourself is if less than $50 now is worth saving you not being able to use the other $25k you have in V4+ content on G3F.
If the answer is yes, then buy them. If not, then skip it, or try and make your own clones/skirt templates. I know which way i voted. My only real niggle is that they didn't get as far back as Generation 3-- I have some really cute stuff for Aiko that I'd like to use again.
Thanks Dark. Food for thought.
