Kola 8.1 Face Cyber Markings (Solved)
jjoyner
I bought Kola 8.1 (https://www.daz3d.com/kola-81) a few days ago. For anyone who has bought Kola 8.1, have you experimented with trying to change the color or intensity of his face cyber markings. He comes with two materials - Face Cyber Glow – Blue and Face Cyber Glow – White. I have found nothing in any of the surface or parameter setting that I could change in order to change the color to something other than blue or white or to change the intensity. If anyone has tried, I’d like to know if you were successful (and how) or unsuccessful. Thanks in advance.
Post edited by jjoyner on
You can select Shell Face node in Scene pane, locate Face surface in Surfaces pane, then change Eimission Color as well as Luminance value.
Thanks much for your reply. Unfortunately, I do not have a Shell Face node. Any idea as to why not? I launched Kola 8.1 in both Daz Studio 8.21 and 8.24. I checked the File List in DAZ3D and found no mention of Shell Face. Did your install include a Shell Face? Any advice that you can offer will be appreciated.
The shell wearables are under Materials category (wrongly-defined category....). Load it to the figure firstly. :)
After exploring more, I saw that when I added the shell wearable, the Shell Face node appeared and I could change the color under Surfaces. "Simple" things shouldn't be so hard.
Update: I created a new category called Shell and added that categorization to the four wearables for cyber face and cyber eyes.
Nice !
