Englevinge Monokini G8F
(Images Removed by mod)
A model of an angel wing-themed monokini style ladies' swimsuit, rigged in DAZ Studio for Genesis 8/8.1 Female. 2648 polys. A good assortment of Iray materials are included, as well as some shaders that allow for various degrees of transparency simulating thread weave. NB: the material files included are shared with my various other swimsuit models.
NB: There is a special adjustment morph for the front side strings below the breasts called "BB Strings" that will work with the smoothing modifier to help the strings have a more natural appearance with much larger or smaller breasts from the default morph. You may also want to tinker with the Push/Offset modifier in some cases.
Download: RenderHub (login required)
Download: Google Drive
Thanks. Looks interesting and fun.
The funnest bit I can imagine, though, is my lady wife trying to put it on, and only getting the leg & arm holes after multiple failed attempts between the wrong straps.
Regards,
Richard
yeah there's a reason swimsuits tend to be your basic one piece or triangle bikini :3
