Installing Michael4 in Poser on Mac?
I prchased IM00007877-01_Michael4Base .
I put in Poser 13 >Runtime > Figurs .
When I open in Poser 13 Figures, No DAZ #D People are in cluder.
I must be in wrong folder. Help,
How did you install? Using Instal manager is best, then make sure you seelct the same folder for isntallation as you have selected as an external library folder in Poser (that is, the folder that holds the "Runtime" folder).
In order to use Michael 4 correctly you need to make a list of all the morph files that Poser will read on loading the base figure, that requires running the /Runtime/Libraries/!DAZ/DzCreateExPFiles-m4 command script - which will at least require making sure that gatekeeper etc. allow the base DzCraeteExPFiles.app executable.
M4 needs a one-time offline "activation", after installing. Tutorial, which also covers the ++ morphs: https://jurn.link/dazposer/index.php/2017/12/28/tutorial-how-to-activate-and-load-micheal-4-and-morphs/
It neds to be done everytime a ne ExP product (most morph sets, some characters) is added so that Poser reads the files that add the channels into which the morph data is injected.
