UltraScenery
I have no content in the features tab in the ultrascene creator.
can anyone advise.
  • Temp Data:
    2025-11-13 17:42:42.797 [INFO] :: Location = C:/Users/User/AppData/Roaming/DAZ 3D/Studio4/temp/UltraSceneryTmp
    2025-11-13 17:42:42.797 [INFO] :: Disk Total: 475.9 GB (511099006976)
    2025-11-13 17:42:42.797 [INFO] :: Disk Avail: 32.8 GB (35323277312)
    2025-11-13 17:43:16.801 [WARNING] :: Script Error: Line 163
    2025-11-13 17:43:16.801 [WARNING] :: TypeError: Result of expression '_this.oFeature' [null] is not an object.
    2025-11-13 17:43:16.801 [WARNING] :: Stack Trace:
    <anonymous>()@H:/Users/Public/Documents/My DAZ 3D Library/environments/landscapes/ultrascenery/ultrascenecreator.dse:163
    2025-11-13 17:43:16.807 [WARNING] :: Error in script execution: H:/Users/Public/Documents/My DAZ 3D Library/environments/landscapes/ultrascenery/ultrascenecreator.dse
    This is the Log File
  • How did you install?
  • westcalawestcala Posts: 27
    I instaled with DIM
  • Richard HaseltineRichard Haseltine Posts: 108,773
    Do you work with Daz Studio logged in or with it offline?
  • barbultbarbult Posts: 26,420
    The user is logged in. The screenshot shows the "Work Offline" button.
    Thanks.
    The script path doesn't look as if a Connect instal has slipped in to confuse the issue, as can happen if you work online. Does the C: drive, with the temp folder, have space? What happens if you move the Temp folder to another drive (Edit>Preferences has the option for doing that)?
