A great tool to use alongside Daz: material maker
I've recently been using a piece of software called "material maker" that is a node-based shader editor similar to the one in blender, except for one key difference that makes it way better for using in conjunction with daz: you can click a node in the node tree and then export the image as it appears at that point in the tree.
so I've been using it to scale up normal maps for combining them with higher detail ones, making noise maps and converting them into tileable roughness maps, and so on and so forth. with large textures, I can do things way faster than I can with the layered image editor and I don't have to worry about filling up the temp folder and bogging down the computer.
the link is here, check it out! https://www.materialmaker.org/
Moved to Art Studio as it is not about Daz Studio per se.
