Kitbash model in Daz
I'm trying to load in Daz Studio the Lit Brazier model from 'Enchanted'.
I have imported it into Blender where it looks fine and then exported it. When I import it into Daz, there is something that looks like a card that the flames are drawn onto. See attached screenshots so you can see what I'm talking about.
How do I export it so that the 'card' is not there?
  • The 'cards' are an indication of a missing transparency/opacity map.
    If you plan to keep the flames, you'll ned ot find the missing texture.
    If you don't plan to use the included flames, you'll need to determine which object, or polygons, that is, and remove it/them before export.
  • I have been assured by Kitbash technical support that everything, including the transparency file, is in place in Blender.
    How/where do I find the missing texture?
    Alastair
  • UnseenUnseen Posts: 766
    edited November 2025
    I have this plugin and it works beautifully when I send an item from Blender to Daz:
    https://www.daz3d.com/blender-to-daz-studio-plugin
    Until now, all the models I have sent to Daz all had their textures.
    JAWOTP
    Post edited by Unseen on
