Is it possible to make a preset of camera setting?
I usually create a camera and define certain properties, for example:
Display Focal Point Scale:
- uncheck use limits
- value: 1000%
Headlamp Mode: Off
I want to know if it is possible to save a preset with this configuration and apply it to new cameras in order to save time changing these values.
Thank you in advance
  • crosswindcrosswind Posts: 9,747
    Yes, you want to save them as a Properties Preset: File > Save As > Properties Preset...
    Uncheck all in Pose tab, then check Focal Point Scale and Headlamp Mode only in Other tab.
    806 x 802 - 62K
  • faibolxfaibolx Posts: 77
    Awesome! Thank you very much for your help. I tried that preset but forgot to explore tabs blush
