I have a problem with Daz3D 2025 (6.25).
minsung621minsung621 Posts: 23
edited October 2025 in New Users
Hello.
https://www.daz3d.com/forums/discussion/746521/i-m-having-a-problem-with-daz3d-2025-6-25
After experiencing this issue, rendering quality in Daz3D deteriorated.
Is there a solution?
Post edited by minsung621 on
  • felisfelis Posts: 5,933
    Try to increase subD on the shirt.
    What I'm talking about isn't the object being rendered sub-D, but the viewport's resolution appearing low...
    Is there a way to fix this?
    Your viewport will be the number of pixels it take up on your screen. So if you are in full screen mode you can only hide the timeline if that is preset, and then the sidebars if they then will limit the viewport.
  • crosswindcrosswind Posts: 9,639
    edited October 2025
    In the similar way, change View SubD Level to 2.... because the base mesh of Dress you made is a bit sparse.
    Then, with NVIDIA Iray Draw Style, in Draw Settings pane, change Drawing >Draw Mode to Photoreal, Optimization > Texture Compression to Off.
    2560 x 1392 - 1M
    Post edited by crosswind on
    Thank you for your reply!
    Have a nice day!
