Black screen in Daz3D
Hello there!
Out of the blue a few weeks ago Daz "crashes" for me. Its not a blue screen crash because things in the background are still going. E.g if I'm listenting to a Youtube podcast I can still hear it going on and light is still being emitted from the PC and my peripherals. It just turns off the monitors. Only way to fix it is by doing a hard-reset on the PC. I've seen some similar threads were people say its a VRAM issue. Yet why would this happen to me out of the blue? Sure I only got 10gb but that has always been enough and these aren't resource intensive scenes we are talking about. I've even done close-up 6 charachter renders before and it have worked fine. It can even occur during me playing around in Filament. I've been using Daz3D for a couple of years now, so I don't really get why this issue have popped up.
What I have done;
  • Updated my GPU and monitor drivers
  • Updated Daz3D to 4.24.0.3
  • Cleaned out my PC
Here is a example log:
2025-10-20 17:03:20.254 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : found 194 textures, 0 lambdas (0 unique)
2025-10-20 17:03:20.255 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Emitter geometry import (1 light source with 2 triangles, 1 instance) took 5.900 us
2025-10-20 17:03:20.255 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating compiled material code.
2025-10-20 17:03:20.255 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating material textures.
2025-10-20 17:03:20.258 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating BSDFs.
2025-10-20 17:03:20.258 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating volumes.
2025-10-20 17:03:20.258 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lights.
2025-10-20 17:03:20.258 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating object flags.
2025-10-20 17:03:20.258 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating decals.
2025-10-20 17:03:20.260 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using iray core convergence estimate.
2025-10-20 17:03:20.260 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Allocating 1-layer frame buffer
2025-10-20 17:03:20.262 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using interactive scheduling, caustic sampler disabled
2025-10-20 17:03:20.263 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 1 device(s):
2025-10-20 17:03:20.263 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3080)
2025-10-20 17:03:20.263 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
2025-10-20 17:03:20.263 Iray [INFO] - IRAY:RENDER ::   1.14  IRAY   rend progr: CUDA device 0 (NVIDIA GeForce RTX 3080): Processing scene...
2025-10-20 17:03:20.302 Iray [INFO] - IRAY:RENDER ::   1.15  IRAY   rend info : Importing lights for motion time 0
2025-10-20 17:03:20.302 Iray [INFO] - IRAY:RENDER ::   1.15  IRAY   rend info : Initializing light hierarchy.
2025-10-20 17:03:20.302 Iray [INFO] - IRAY:RENDER ::   1.15  IRAY   rend info : Light hierarchy initialization took 493.200 us
2025-10-20 17:03:20.305 Iray [INFO] - IRAY:RENDER ::   1.14  IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3080): Scene processed in 0.042s
2025-10-20 17:03:20.306 Iray [INFO] - IRAY:RENDER ::   1.15  IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3080): Allocated 11.616 MiB for frame buffer
2025-10-20 17:03:20.307 Iray [INFO] - IRAY:RENDER ::   1.14  IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3080): Allocated 2.094 GiB of work space (2048k active samples in 0.000s)
2025-10-20 17:03:20.307 Iray [INFO] - IRAY:RENDER ::   1.14  IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3080): Optimizing for cooperative usage (performance could be sacrificed)
2025-10-20 17:03:20.329 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00001 iteration after 62.666 ms.
2025-10-20 17:03:20.330 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
2025-10-20 17:03:20.374 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00002 iterations after 102.712 ms.
2025-10-20 17:03:20.375 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
2025-10-20 17:03:20.418 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00003 iterations after 142.999 ms.
2025-10-20 17:03:20.419 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
2025-10-20 17:03:20.462 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00004 iterations after 182.830 ms.
2025-10-20 17:03:20.464 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
2025-10-20 17:03:20.507 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00005 iterations after 226.756 ms.
2025-10-20 17:03:20.550 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00006 iterations after 268.478 ms.
2025-10-20 17:03:20.592 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00007 iterations after 309.906 ms.
2025-10-20 17:03:20.634 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00008 iterations after 352.121 ms.
2025-10-20 17:03:20.675 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00009 iterations after 393.723 ms.
2025-10-20 17:03:20.717 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00010 iterations after 435.476 ms.
2025-10-20 17:03:20.759 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00011 iterations after 477.231 ms.
2025-10-20 17:03:20.801 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00012 iterations after 519.387 ms.
2025-10-20 17:03:20.857 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00014 iterations after 575.434 ms.
2025-10-20 17:03:20.925 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00017 iterations after 643.529 ms.
2025-10-20 17:03:21.006 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00021 iterations after 725.229 ms.
2025-10-20 17:03:21.101 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00026 iterations after 819.348 ms.
2025-10-20 17:03:21.194 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00031 iterations after 912.875 ms.
2025-10-20 17:03:21.287 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00036 iterations after 1.006 s.
2025-10-20 17:03:21.382 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00041 iterations after 1.101 s.
2025-10-20 17:03:21.539 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00051 iterations after 1.259 s.
2025-10-20 17:03:21.724 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00063 iterations after 1.442 s.
2025-10-20 17:03:21.919 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00076 iterations after 1.638 s.
2025-10-20 17:03:22.117 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00089 iterations after 1.836 s.
2025-10-20 17:03:22.311 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00102 iterations after 2.030 s.
2025-10-20 17:03:22.506 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00115 iterations after 2.225 s.
2025-10-20 17:03:22.701 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00128 iterations after 2.421 s.
2025-10-20 17:03:22.898 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00141 iterations after 2.616 s.
2025-10-20 17:03:23.093 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00154 iterations after 2.812 s.
2025-10-20 17:03:23.288 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00167 iterations after 3.007 s.
2025-10-20 17:03:23.483 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00180 iterations after 3.202 s.
2025-10-20 17:03:23.679 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00193 iterations after 3.398 s.
2025-10-20 17:03:23.875 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00206 iterations after 3.593 s.
2025-10-20 17:03:24.071 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00219 iterations after 3.789 s.
2025-10-20 17:03:24.266 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00232 iterations after 3.985 s.
2025-10-20 17:03:24.461 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00245 iterations after 4.180 s.
2025-10-20 17:03:24.656 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00258 iterations after 4.376 s.
2025-10-20 17:03:24.874 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00271 iterations after 4.593 s.
2025-10-20 17:03:25.084 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00283 iterations after 4.802 s.
2025-10-20 17:03:25.258 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00294 iterations after 4.976 s.
2025-10-20 17:03:25.445 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00306 iterations after 5.164 s.
2025-10-20 17:03:25.634 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00318 iterations after 5.353 s.
2025-10-20 17:03:25.820 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00330 iterations after 5.539 s.
2025-10-20 17:03:26.017 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00343 iterations after 5.736 s.
2025-10-20 17:03:26.218 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00356 iterations after 5.937 s.
2025-10-20 17:03:26.420 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00369 iterations after 6.139 s.
2025-10-20 17:03:26.621 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00382 iterations after 6.340 s.
2025-10-20 17:03:26.815 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00395 iterations after 6.533 s.
2025-10-20 17:03:27.012 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00408 iterations after 6.730 s.
2025-10-20 17:03:27.207 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00421 iterations after 6.926 s.
2025-10-20 17:03:27.404 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00434 iterations after 7.123 s.
2025-10-20 17:03:27.606 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00447 iterations after 7.325 s.
2025-10-20 17:03:27.812 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00460 iterations after 7.531 s.
2025-10-20 17:03:27.997 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00472 iterations after 7.716 s.
2025-10-20 17:03:28.193 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00485 iterations after 7.912 s.
2025-10-20 17:03:28.393 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00498 iterations after 8.111 s.
2025-10-20 17:03:28.597 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00511 iterations after 8.316 s.
2025-10-20 17:03:28.786 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00523 iterations after 8.505 s.
2025-10-20 17:03:28.973 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00535 iterations after 8.692 s.
2025-10-20 17:03:29.159 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00547 iterations after 8.878 s.
2025-10-20 17:03:29.356 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00560 iterations after 9.074 s.
2025-10-20 17:03:29.553 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00573 iterations after 9.272 s.
2025-10-20 17:03:29.751 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00586 iterations after 9.469 s.
2025-10-20 17:03:29.948 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00599 iterations after 9.666 s.
2025-10-20 17:03:30.145 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00612 iterations after 9.864 s.
2025-10-20 17:03:30.348 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00625 iterations after 10.067 s.
2025-10-20 17:03:30.717 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00651 iterations after 10.435 s.
2025-10-20 17:03:31.418 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00703 iterations after 11.137 s.
2025-10-20 17:03:32.514 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00785 iterations after 12.233 s.
2025-10-20 17:03:33.760 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00876 iterations after 13.479 s.
2025-10-20 17:03:35.072 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00974 iterations after 14.790 s.
2025-10-20 17:03:36.543 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 01084 iterations after 16.261 s.
2025-10-20 17:03:38.172 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 01205 iterations after 17.891 s.
2025-10-20 17:03:39.937 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 01337 iterations after 19.656 s.
2025-10-20 17:04:02.889 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(373): Iray [ERROR] - IRAY:RENDER ::   1.32  IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3080): Kernel [13] (MaterialSurface   ) failed after 21.400s
2025-10-20 17:04:02.890 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(373): Iray [ERROR] - IRAY:RENDER ::   1.32  IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3080): unknown error (while launching CUDA renderer in <internal>:904)
2025-10-20 17:04:02.890 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(373): Iray [ERROR] - IRAY:RENDER ::   1.32  IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3080): Failed to launch renderer
2025-10-20 17:04:02.890 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(373): Iray [ERROR] - IRAY:RENDER ::   1.14  IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3080): Device failed while rendering
2025-10-20 17:04:02.890 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(373): Iray [WARNING] - IRAY:RENDER ::   1.14  IRAY   rend warn : CUDA device 0 (NVIDIA GeForce RTX 3080) is no longer available for rendering.
Any type of help would be appreciated. Thanks in advance!
  • crosswindcrosswind Posts: 9,537
    edited October 20
    - Which Nvidia driver are you using ? Try latest NSD driver (Nvidia Studio Driver) if it's not .... But before that, better fully uninstall Nvidia drivers by using latest DDU
    - Also check DS settings in NVIDIA control panel, try resetting the configurations.
    - How did your PSU perform ? with how many watts ?
    Post edited by crosswind on
  • Richard HaseltineRichard Haseltine Posts: 107,857
    Heat of the GPU?
  • LorraineLorraine Posts: 877
    Richard Haseltine said:
    Heat of the GPU?
    This was causing my black screen. I fitted extra case fans and cranked up their speed, plus installed MSI Afterburner and use it to control the speed of the GPU fans. That seems to have solved my problem.
    Hello! I wasn't on the latest studio driver, I was on a game driver. I updated it to the latest studio driver and it went better in the viewport but it crashed anyways during the render. Same crash, not a bluescreen, background applications are still running. Just a complete blackscreen. How do I check the DS settings in the NVIDIA control panel? My PSU is 900W. Maybe a bit too low for the GPU but it has never been an issue in the past.
  • Richard Haseltine said:
    Heat of the GPU?
    46C, I even did a spring cleaning yesterday cause I thought it might be a heat issues but my PC is cold and there was minimal dust.
