Collision Offset
What do I need to do when I start a dForce simulation and one of the clothing objects dump 22,000 logs that look like this? Is this bad? It must be. Invariably, this is a dForce object that is going to explode 20 seconds into the simulation.
2025-10-19 19:43:06.852 [INFO] :: Spring(8086, 8088) of node "Radiant Dress G9" extended: rest length < collsion offset (0.102283 < 0.20001)
2025-10-19 19:43:06.852 [INFO] :: Spring(8087, 8089) of node "Radiant Dress G9" extended: rest length < collsion offset (0.1073 < 0.20001)
  • felisfelis Posts: 5,816
    edited October 20
    In the surface settings, in the dForce group, there is a collision distance, and the simulation target to keep everything at collision distance.
    So if you have a mesh where parts of it the vertex distance are below the collision distance you will get that warning. If you have a smaller amount of warnings it is usually fine.
    But with many warnings there is a big risk the it will explode during simulation.
    You can lower the collision value in surface settings, just be aware that it will also impact e.g. collision with a character with a higher risk of clipping.
    If it is something you have modelled yourself, you should investigate in your model if the density is needed. You can have different collision distance per surface.
    Edit: what I call collision distance is formally collision offset.
    Post edited by felis on
  • I have, with some Poser Dynamic Cloth conversions, resorted to scaling the characters up by 5x or 10x before doing the simulation as a number of entire facets were smaller than the collision distance and rather than fiddle with all the collision settings I just scaled the character. If the facets or collision distance are too small I fear that you can get into decimal point rounding problems. Anyway, it's just a different way of doing what @felis suggested.
    Regards,
    Richard
  • crosswindcrosswind Posts: 9,588
    Whether it's bad or not depends on different case: 1) not really bad but just time-consuming with the dForce ready garments you bought... because vendors usually tested the produts; 2) more or less bad with the non dForce ready garments to which you added dForce Modifier ~~
    In your case, the vertices that have lower distance than preset Collistion Offset are preared to "sprung" to default 0.2cm... but you can reduce Collision Offset to 0.08 ~ 0.09 on dynamic surface(s), as well as increase the value a bit in Contraction-Expansion Ratio, to give it a test.
    Save your Scene beforehand ~ smiley
  • One should ALWAYS save the scene before any render, any simulation, any creation of an ultrascenery scene, basically any big operation in DS.
    Regards,
    Richard
  • jmucchiellojmucchiello Posts: 657
    No, I've never made any clothing. This is a store asset. https://www.daz3d.com/dforce-radiant-dress-genesis-9-and-genesis-8-female
    edited October 20
    Hmmm, it is a fairly simple dress. I see no reason for it to have such high mesh density.
    How many faces are there in the dress? If you select the dress in the scene tab, and click info you can see mesh details.
    Have you tried to lower collision offset?
    dForce Radiant Dress Genesis 9 and Genesis 8 Female works well on my side. They can be instantly simulated with out-of-box settings on G8/G9 Base... with spring report for around 0.5 second.
    They should perform the same on other characters... even on heavily-customized ones ~
    Primary Selection :
    Name :
    G9 Base V3_8093
    Label :
    Radiant Dress G9
    Class :
    DzFigure
    Vertices :
    32,089 / 8,093
    Triangles :
    0 / 8
    Quads :
    31,796 / 7,943
    Total Faces :
    31,796 / 7,951
    Total Lines :
    0 / 0
    I finally loaded the figure and dress/hair (and nothing else) into a separate scene. I set the collision offset to 0.080.
    Memorized Pose OFF: it took 15 seconds and there was pokethru. Not unexpected.
    Memorized Pose ON: 52 seconds and it looks great. There was only one spring note in the log file:
    2025-10-20 12:58:39.640 [INFO] :: Spring(0, 1) of node "Radiant Dress G9" extended: rest length < collsion offset (0.0234624 < 0.08001)
    2025-10-20 12:58:39.648 [INFO] :: Shortest spring had length: 0.0234624
    2025-10-20 12:59:28.811 [INFO] :: Total Simulation Time: 51.39 seconds
    Neither simulation with the new setting exploded. That solved the problem.
    edited October 20
    Ah, that's great but odd ~   On my side, I only see a couple of springs in DS log: (ss1)
    I don't know why it performed differently on your side ~~ or that long report of springs might come from other dForce items....
    2560 x 1392 - 507K
    Post edited by crosswind on
