Corset Lingerie Set G3F crash issues!
KA1
in The Commons
I picked up http://www.daz3d.com/corset-lingerie-set-for-genesis-3-female-s along with the texture pack to use the stockings and gloves for some Femme Fatale scenes I'm working on. Seemed like the perfect set for it except it won't render. Any scene I include any of the items in will freeze when I hit iRay to render and will either freeze indefinitely or eventually crash Daz with a fatal error, anyone else have any issues with this set?
I'm having the same problem with a different item.
Try this for me please,,,
On the Surface pane, Select the items and remove the maps in "base Color"
now try to do an iray render..
This is how I got it to render, but thus means I have no textures :(
I can apply 3Delight materials, then use CTRL+ click to swap them over to iray uberbase and this works, but the iray preset crashes Studio everytime.
I have the corsette set & it crashes because it loads at Sub D 5.
I loaded it & dialed it all back to 1 & resaved but I probably should have raised a bug report
Hope that helps
I could have sworn I've used this before, but it seems I remembered wrong. I set up a test render and I get the same the result. It just won't render.
Where do you find that so you can change it?
Just go to - Parameters - Mesh Resolution - Render SubD level (Minimum)
You can select all the items of the set in your scene & just do 1 change to SubD 1 or 2
Much thanks Tottallou! That certainly did the trick. The Shoes and stockings are already at 1, which explains why I was certain I've used this set before, because I've definitely used the shoes in other renders. But the gloves was at 4 and the corset and panties at 5. Setting those to 1 as you suggested made rendering possible.
Excellent, thank you so much!!
