Rundown Rooms
marblemarble Posts: 7,500
edited October 2015 in The Commons
Again I have to ask a vendor to please provide a better description of a product. I really don't like having to buy something to find out if it will be suitable. Sometimes, in sales, there is no chance of returning the purchase, which makes the buy & try option even worse.
Rundown Apartment, Bedroom and Hallway: are we able to hide walls? Can they be used together (door opens into the other room or Hallway, for example)? Is the radiator included in the props for the Apartment (it isn't listed)?
This store really needs a rating system so that buyers can comment. Having to search the forums in the often vain hope that someone might have left a comment is not good enough.
Post edited by marble on
  • cosmo71cosmo71 Posts: 3,609
    edited October 2015
    you can hide every wall also the ceiling and also the single props loaded with the set (if you use preload) and you have seperate props as listed you can load into a scene, have just bought all the stuff but not testes everything... doors can be opened/closed, Radiator is not an extra prop. But so far I must say, cool stuff these sets and also the props. And here is a first render with the apartement smiley
    1650 x 875 - 342K
    Post edited by cosmo71 on
  • marblemarble Posts: 7,500
    Thanks for clarifying.
    By the way, are they open fronted sets or is there a fourth wall. I'm thinking of the alternate perspective from the point of view of someone watching the TV.
    edited October 2015
    the presets are complete rooms , 4 walls, ceiling, floor but each is selectable. But you need something as backround for the windows.
    That's fine ... grabbed the Apartment and Bedroom.
    Thanks.
  • EtriganEtrigan Posts: 603
    I won't bother with this one. Like Marble, I wish they'd be explicit in the product description. I deduce, though, that there are only Iray materials included? One texture set and all Iray promos.
    I don't use Iray either so it will be interesting to see how Reality/Luxrender copes with the Iray shaders. However, I've just looked at the product page again and it does state "3Delight Versions".
    I stand corrected. I will, however, swear it wasn't there a half hour ago.blushcheeky
    I use just 3Delight, one reason my old machine and another, I have no need to render as realistic as possible and btw a lot of iray renders I have seen so far are looking a bit too high illuminated in my opinion maybe this is a result of values or it is a general issue. I do not know.
