crashing when running daz to unreal
when i run the daz to unreal export it gets almost done and then crashes. I have uninstalled and reinstalled daz and still same issue.
I have uninstalled everything and reinstalled everything and still the same issue
Suggest you disable all other non-Daz official plugins in Help > About Installed Plugins..., then try again to see what'll happen ~~
Post the dump files saved from the fatal error dialogue and attach a zipped file down below... if the issue persists. We may help with finding some clues if possible ~~
come to find out i was doing cntrl and click to hide the items and this is what was causing the crash cause if i just click to hide without cntrl it worked correctly
