Monster smile for M6
Hello, I'm looking for a way to morph M6 face to make him look like Spiderman's Venom.
So far, I think I managed to make the eyes and nose disappear so he has a "blank" face, but I have found no solution to give him the monster's "smile".
Any help would be greatly appreciated !
  • Oso3DOso3D Posts: 15,095
    It might be worth looking into modifying the skin texture to make the bits around the corner of the mouth transparent. Trying to make the mouth super big runs into potential distortion problems.
    Rendering up an experiment, incoming to the 'show your iray' thread.
    Here: http://willbear.deviantart.com/art/Monster-smile-568658373
    Note that it's mildly gory.
  • IvyIvy Posts: 7,165
    edited October 2015
    Did you mean like a Joke type smile?
    You could try playing with the morph settings. you will need the characters head morphs sets for what ever generation your working with to manipulate the morph.  I will use Genesis 2 male for my example model if that helps.
    Under Perimeters click <pose controls then click >head then >Mouth.
      Once you click Mouth  scroll down this list for the mouth morphs you should find the mouth morph smile, & smile open  Perimeters settings.  , and  can use those smile mouth settings to increase an and manipulate the smile . .. if you need a bigger smile than the morph your working with. Click the Perimeters setting  as showing in the first capture (pic1).  from there you can change the max  morph limit setting from 1 to say like 3 or 4  next click "Accept" and then make your adjustment again and see if that give you what you want.see capture 2 (pic 2) for example  the increase morph setting change looks like . you can do this with any of the morphs settings , you may need to click the paddle lock on some of the morphs to access the Perimeters settings .. I hope that helps . That would be the only way I would know how to do what your looking for with morphs
    Good Luck
    1889 x 1104 - 226K
    1888 x 1138 - 217K
    Post edited by Ivy on
  • Thank you very much to both of you !
    I'll try Will's solution, since I've already been playing with mouth morphs (turning off the limits, by the way), and while the result would make a good Joker, it doesn't have the "piranha's jaw" look I'm trying to achieve.
    A combination might be good, too... a little stretching.
    Two comments: First, the jaw and inner mouth is designed for a fairly normal mouth, so you have to be careful and play with morph dials for size of jaw (I made their width something like 600%), or you just see these huge gaps into the head.
    Second, you want to shut off translucency and SSS, or you will still see gaps into the dimly lit interior of the head, which just looks silly.
  • JUJUJUJU Posts: 1,133
    Do you mean the spiky tooth?
    Here are some tooth morphs
    http://www.daz3d.com/creature-creator-hd-for-genesis-2-male-s
  • LindseyLindsey Posts: 2,011
    edited October 2015
    Hellboy created a Venom character morph for Freak 4, sans tongue, but I didn't find it in his freebie offerings at Sharecg and couldn't figure out if it was offered at his account on Deviant Art.  The package cannot be redistributed and can only be obtained from him.  I suggest you send Hellboy site mail here and see if he has it posted for download somewhere or maybe a forum user here has an authorized download link they can post.
    927 x 1200 - 239K
    Post edited by Lindsey on
    Holy smoke, yeah, that's nice.
    If it surfaces on Sharecg or somewhere else, let us know!
    Nobaody except Hellboy will have an authorised download
    edited October 2015
    Sorry, to clarify I meant a link/URL that was originally posted by Hellboy such as a link to a freebie posted on his ShareCG account.
    here is one
    http://www.sharecg.com/v/37023/browse/5/3D-Model/Venom
    there are some more on sharecg
    Hrm. Guess I'll have to pick up the 'gen 3 addon' for GenX if I want to use that. Bah. ;)
