TheAntFarm's MAG 2 Robotic Arm Help Please: Solved Thank you
Headwax
Hi, Carrara user here trying to get a handle on this.
http://www.daz3d.com/m-a-g-2-robotic-arm
I get the same error in both Studio 4.7 and Carrara 8.5 - that the programs cant find dsf files.
For example in Studio clicking on the MechArmL in the content library I get an error window
saying cant find /data/TheAntFarm/MechArm/MechArmLeft/mag2_208711.dsf
When I go to my folders though, the file is there.
I'm on windows7 and know nothing about Studio at all.
Am I supposed to point Studio at the file?
Thanks for advice
cheers
Post edited by Headwax on
Is the folder that contains the Data folder listed in DS as a DS-format content folder? What's the full path?
hya thanks for replying so quickly!
full path is E:MyDaz3dLibrary/data/TheAntFarm/MechArm/MechArmLeft/
I'm not sure how to acertain whether "the folder that contains the Data folder listed in DS as a DS-format content folder"
How would I check this? Sorry to be a numbskull ;)
Edit > Preferences > Content Library > Content Directory Manager
this is my working window if that helps?
sorry just saw your reply Fixmypcmike
I have this , does this look correct?
You need to add "E:\MyDaz3dLibrary" under both Daz Studio Formats and Poser Formats in the Current Directories
Thank you for that! I'll do that when I get back to my PC
Appreciate the help, thank you.
Thank you again, that solved the problem!
Cheers
