Halloween Style Neck & Temple Bolts
richardandtracy
I have come up with a pair of Bolts to go through G8F's neck and temple. Each bolt consists of a bolt, a nut and a spacer tube. One is located in G8F's neck, the other in her temple.
These are wearable presets, and include some information on hiding neck and temple facets, so you can see through the spacer tube when it's fitted. It isn't perfect as some of the neck/temple facets can be seen in the apertures, I really needed a geograft, however it's OK at a little distance. The neck bolt is distorted by bending and twisting the neck - so not perfect, but may well be adequate for your purpose.
There is a bolt withdrawal morph. The nut and bolt can be hidden, and a spare bolt is supplied. The pose below (brain being scrambled as the temple bolt is withdrawn) is included.
Please let me know if there are any issues other than the ones mentioned. I have had my own brain scrambled by COVID, so may have missed something.
Have fun with it, please.
Regards,
Richard
Very nice, just in time for Halloween! Thank you!
