Dforce Works In 4.12 Beta But Not in 4.24 Solved
IceDragonArtIceDragonArt Posts: 12,792
I've successfully loaded the 4.24 alongside the 4.12 Beta.  The 8.1 and 9 figures work much better in the newer version but the Dforce does not work at all. Works very well in the earlier beta version but just locks up immediately and I have to shut the entire thing down.
Device Name MSI
Processor Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz   2.80 GHz
Installed RAM 16.0 GB (15.9 GB usable)
Storage 932 GB HDD HGST HTS541010B7E610, 238 GB SSD TOSHIBA THNSNJ256G8NY
Graphics Card NVIDIA GeForce GTX 1060 (6 GB), Intel(R) HD Graphics 630 (128 MB)
Device ID E39EC347-3C8F-4F99-A040-85D2D7FFC2E2
Product ID 00325-96227-43080-AAOEM
System Type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
  • Richard HaseltineRichard Haseltine Posts: 108,227
    No error messages?
  • IceDragonArtIceDragonArt Posts: 12,792
    2025-10-10 19:32:37.063 [ERROR] :: Open File Failed - Could not read file: /data/DAZ 3D/Genesis 8/Female/Morphs/3D Universe/G8FPoseArchitect/p3DUPATorsoShiftWeightN_R.dsf
    2025-10-10 19:32:37.078 [ERROR] :: Open IO Device Failed - Access is denied.: E:/My DAZ 3D Library/data/DAZ 3D/Genesis 8/Female/Morphs/3D Universe/G8FPoseArchitect/p3DUPATorsoShiftWeight_L.dsf
    2025-10-10 19:32:37.078 [ERROR] :: Open File Failed - Could not read file: /data/DAZ 3D/Genesis 8/Female/Morphs/3D Universe/G8FPoseArchitect/p3DUPATorsoShiftWeight_L.dsf
    2025-10-10 19:32:37.100 [ERROR] :: Open IO Device Failed - Access is denied.: E:/My DAZ 3D Library/data/DAZ 3D/Genesis 8/Female/Morphs/3D Universe/G8FPoseArchitect/p3DUPATorsoShiftWeight_R.dsf
    2025-10-10 19:32:37.100 [ERROR] :: Open File Failed - Could not read file: /data/DAZ 3D/Genesis 8/Female/Morphs/3D Universe/G8FPoseArchitect/p3DUPATorsoShiftWeight_R.dsf
    This is the error log.  its not just this pose either.  it locks up as soon as the little box appears and then says Daz Studio not responding.  Which isn't totally unusual sometimes it takes a minute for things to load but I let it go for more than half an hour and absolutely nothing happens and I have to shut it down to get out of it.
    Are you sure the path is correct, including the drive letter? Access denied sounds like an issue with the hardware or identifiers.
    I elieve so, everything else is where it should be.  But I will do some digging  everything else works as inteneded so far, everything loads on to the character with no error messages etc.
    Okay I finally found the issue.  I needed to go into the advanced settings and change it from the opengl to the nvidea setting.  Works perfectly now.  Thanks!
