Filatoon & Displacement
Can displacement maps be used with Filatoon?  I saw that it is available in the Filatoon Metallic shader when I check the "show hidden properties" option on the shader panel, but when I put a map in the displacement strength property and set a non-zero strength, nothing happens.  I turned displacement strength up to 2, minimum to -10, maximum to +10 and displacment subD to 1.  Still no change.  Am I missing something?
  • If you have to enable Show Hidden proeprties to see a property then it probably shouldn't be used - it may not be relevant (zeroing various strength sliders in the Iray Uber base will hide dependent properties; lights will show different properties depending on whether 3Delight or iray is the current render Engine and so on) or it may be set indiectly from other properties or it may be needed but not adjustable. I would think in this case it is the first that applies, it doesn't have any effect in this context.
