Vintage Television Sets - Says textures included - Iray? 3Delight?
cosmo71cosmo71 Posts: 3,609
Textures for what? Iray or 3Delight or both?
  • BeeMKayBeeMKay Posts: 7,019
    edited October 2015
    The surface is Iray, but it renders pretty well in 3delight.
    EDIT: It seems that some surfaces, like the Grey Tube of the Nicoll Tandem, are set in 3Delight, while the majority is set in Iray.
    Iray render
    3Delight render
    1200 x 900 - 379K
    1200 x 900 - 410K
    Post edited by BeeMKay on
  • cosmo71cosmo71 Posts: 3,609
    edited October 2015
    Iray render
    3Delight render
    nice and I have one or two questions:
    1. is the light source from the same direction in both renders?
    2. what light did you use in the 3Delight render? I guess with shadow softness you get also good results. I render in 3Delight and use AoA lights and they are really good.
    3. for me Iray looks a bit like the ordinary deep shadow map so nothing new or special.
    Post edited by cosmo71 on
    1. No, I used the default HDR for the Iray (you can tell by the sky reflection in some of the screens) and AOAs Distant&Ambient light for the 3Delight, so totally different lighting.
    2. For 3Delight, I use mostly a combination of AOAs Ambient Light and Distant LIght. But I just roughly added the light to the render; 25% light strength at the ambient, and 70% at the distant. It would probably look bettwer with more tweaking of the lights.
    3. I just added the iray render for quick comparison of the texture between the two render engines. There was no intention to create great art. ;-)
