Daz 4.24 shows as installed in the IM when it shouldn't be.
kyoto kid
...OK this is a bit odd..
Friday night I discovered there was a minor corruption of my copy of Daz 4.21 which affected skin maps of several previously saved characters. I suspect the issue occurred when I was was closing out a scene before shutting down the programme the before night when it went into a "not responding" status for a while (which never happened previously).. I verified this by opening the characters in the 4.20.beta I also have installed and they look fine.(this is why I keep older installers backed up)
Today I went into the IM to uninstall the current copy so I could do a fresh install from the backup in my installer archive. However, couldn't find Daz4.21 i n the installed tab, which instead indicates that 4.24 is installed. I cannot use 4.24 as Nvidia stopped supporting Iray driver updates for WIn7 after the general release ver. 4.21. On the start-up screen for 4,21 it shows the correct release number, so what gives?
This is just a bit confusing..
IIRC DIM displays the name of the latest version of the package when you use it online, even if the version you actually installed is different.
While online, if you go offline it will show the actual version instead.
...thank you.
