[Solved] Need help with "overlapping" morph slider, G2F
bustershotgbustershotg Posts: 10
I only recently noticed a couple morph sliders for my Genesis 2 Females have a (2) in front of them. Specifically Pupils Slit and Pupils Dialate. And the present slider value is a question mark. If I move the slider, I get a normal value, but Pupils Dialate doesn't behave as expected.
I'm guessing I recently installed morphs that effectively added duplicate morph sliders, so I'm sliding more than one morph at once and getting weird results. Is there a way I can look at where a morph slider comes from, so to speak? I don't know when exactly this problem started, so I'm having trouble guessing what might have caused it among all the products I have in DAZ Install Manager.
Post edited by bustershotg on
  • Actually, I just found a solution myself. I guess typing helps me think.
    So: Right click Parameters tab > Preferences > uncheck Consolidate Properties
    Now I do see separate, multiple sliders for Pupils Slit and Pupils Dialate. I can click the small gear icon on each, click Parameter Settings..., and then see the file path for each.
    Looks like ActualEyes4 was the source of the extra morph sliders.
