Timeline: preview speed
yagakisan
Hi all,
i'd want to know if there is a setting to change the animation speed when I use the Play button in the Timeline.
What I need is to slow down the animation to check for errors in the poses.
Is it possible?
Thanks
just go from key to key frame
Yes is what I do now, but I want play the loop at the same speed, changing it at the need.
You need Animate2 to accomplish this. Bake your animaton from the timeline to an aniblock. Then, in edit mode, you can dial the speed to anything you like.
if you use the daz timeline there is an option frame to frame
slows it down
and you can set a playrange there
both not possible with animate timeline
