FM Claustrophobia Caves [Commercial]
Flipmode
Hi there!
Here´s a quick preview for my next set "FM Claustrophobia Caves". It should release in a couple of days.
A set of suitable Crawling Poses (as used in the Previews) will be available as well.
"FM Claustrophobia Caves" offers 19 tight, claustrophobic cave preloads, each for Iray and 3Delight.
(6 Base types, Sidecut versions, Wet versions)
Each cave loads with:
- 1-4 Morphs (e.g. Lower Ceiling).
- 2 Cameras.
- Lighting (a point light is parented to one of the cameras).
- a water plane you can easily move up/down to adjust it´s hight.
The set also includes the rock materials as preloads, allowing you to quickly modify each cave´s surface.
Post edited by Flipmode on
Cool
Adding the links to the products now that they're released:
https://www.daz3d.com/fm-claustrophobia-caves
https://www.daz3d.com/fm-cave-crawling-poses-for-genesis-9-and-8-female
Thanks for posting the links Leana!
I am slightly embarrassed for not thinking of it myself
Quick test with LowPI people.
Thanks for posting your render Artini. :)
Cool to see the set used in such an unexpected way.
Thanks, @Flipmode
You have created a great set of interesting props,
that just screams to be explored further.
I did a lot of crawling in caves in my youth. Just need a little mud to make these Missouri caves.
