Victoria 4
I have prepared a scene with Victoria 4 and i have recorded. When i open i have a message such as that which i enclose. Where I am going wrong? How do I register the file? Thanks
Where is the Runtime\Libraries\!DAZ\Victoria 4 folder? Is the folder that holds that Runtime folder set as a Poser Content Directory in DAZ Studio?
My DAZ 3D Library>Runtime>Libraries>Character>DAZ People>Victoria 4.2.cr2
That wasn't the folder i was asking about - do you have My DAZ 3D Library\Runtime\Libraries\!DAZ\Victoria 4?
reinject the morphs after the scene loads. I think the problem is from having multiple instances of the files on your HD.
Thanks. I deleted all the application "poser" and reinstalled DAZ 3d. Now I have only a single folder with a single runtime, but the problem continues to exist even for classic characters and not reprocessed. I enclose the screen of DAZ is the one with the directory containing the required files and that DAZ is not. I thought to pass from Poser to Daz, but if I do not find a solution, i think i'll have reinstalling the old Poser.
Is the folder containing Runtime setup as a Poser content directory in DS?
I don't know, i have reinstalled everything with" Install Manager". Models of the genesis series work well.
It's woth checking, the default install directory for DIM is not not the same as the default one setup in DS.
This is the window of the installation, i don't know how to intervene. I have made various tests, but i have not achieved any results.
In DS go to Edit > Preferences > Content Library and select "Content Directory Manager"
Look in "Content Sets"-->"Current Directories" --> "Poser Formats". Is the folder which contains your Runtime there? If not,you need to add it.
It looks like DAZ is not finding the correct morph folder. There may be a variation in the morph folder name and the file name that the code is looking for. Or, the morph folder is just in the wrong location. I dont use DIM, I manually install everything. But whenever I misplace a folder or forget to copy over a folder of any type, I get this sort of error. What morphs are you trying to load? They look like morphs++ and Hiro 4, is that right?
