Genesis to Genesis 2 Genx Conversion
I can't get this product to work with the Genesis to Genesis 2 stuff and it doesn't seem to work at all in build 4.8. I've only gotten it to function in 4.7 and 4.5 . I bought both products, so I don't believe that's the issue. I can get the old figures like M4 or V4 to transfer, and I did get the Priestess to transfer but only because she showed up in transfer window after loading the base "source' genesis 1 figure. But she's the only char who has populated into the fields.
I've only found tutorials using the m4 or v4 using the Genx product, can anyone tell me what I should do? The pdf that came with the product has been entirely unhelpful because it only refers to how to use the product with the old content / poser type characters.
Thanks.
I'm using 4.8 and it works fine for me.
Do you have this add on? http://www.daz3d.com/genx2-addon-for-genesis-2
Transfer between the Genesis 1 and 2 characters only works with the addon. If you own it, you might want to re-install it, as sometimes files get lost during upgrades.
(If you speak German, there's an excellent tutorial in German language here: http://www.daz3d.com/forums/discussion/comment/688988/#Comment_688988
It was created by MN-150374
Hi Lee, I do have the upgrade yes. I may try reinstalling it again. Sadly I don't speak german but I'll check it out and see if google translate will work.
Okay... let's see if I get this translated. Like I said, the source is the tutorial http://www.daz3d.com/forums/discussion/comment/688988/#Comment_688988
Transfering Morphs from G1 to G2
GenX2 will now convert the selected Morphs and also a Clone Shape Genesis for Genesis 2 Female.
Heyas lee_lhs, Thanks so much for the info. I finally got it working. It still won't function in 4.8 but it works fine in 4.7 so I'm happy. :)
Do you have two versions of DS installed on the same PC? If yes, that could be part of the problem.
EDIT: Please check if GenX is properly installed in the 4.8 version, too. It's possible that the installer only installed it in the 4.7 version of DS, depending on the path. You can also try to copy the GenX folder from the Plugin folder of 4,7, and paste it to the Plugin folder of 4.8, and then see if that helps.
On a Windows computer the GenX2 installer places GenX2.pdf product documentation in
C:\Program Files\DAZ 3D\DAZStudio4\docs\Plugins\Genesis Generation X2
Or you can access it online here: http://docs.daz3d.com/lib/exe/fetch.php/public/read_me/index/18321/genx2.pdf
EDIT: Sorry, I'm being scatter-brained. As lee_lhs mentioned, you need "GenX2 Add On for Genesis 2" product ( http://www.daz3d.com/genx2-addon-for-genesis-2) which adds Genesis 2 figure to your GenX2 plugin. This will allow you to transfer morphs from Gen4 to Genesis 2 or between Genesis and Genesis 2.
For further clarification, the upgrade to GenX2 maintained the original functionality of transfering Gen4 (and Gen3 with add-ons) to Genesis. What was designed into the GenX2 plugin is the ability to add future Genesis generations into the program, the first being the Genesis 2 Add on product.
TRANSFERRING A CUSTOM CHARACTER
I emphasize with your frustration. When I followed the instructions, I received exaggerated results - such as breasts being abnormally large and waists too small, and faces that were just not right. This is especially true if you use any third party morph as a basis for your character. I just couldn't get it to satisfactorily transfer everything at once. After trying several methods, I managed to find the best method for me:
First picture is Genesis, the second is Genesis 2 Male. Now, they aren't exactly identical, but close enough for me.
What I had to transfer:
Michael 5 Heroic, face: Jaime Character with additional custom face morphs, and Leon & the Night skin.
1. Find All Your Character's Settings.
Load your original character. In Shaping, find every morph and write them down with the names and values. Yes, this is tedious as heck.
2. Create a Transfer of the Third Party Feature.
3. Create a Transfer for Michael 5 Heroic.
4. Loading the Morphs onto Genesis 2 Male.
This is what really tripped me up before until I found what I needed to do.
