Wobble’s Corner - Product Problem
So, I just bought and installed it. Whenever I try to load it up Studio throws errors at me. I have checked and all the files installed where they are suppose to be.
How did you install?
zip file
So manually or with Install Manager?
manually
This product: https://www.daz3d.com/wobbles-corner
It seems the product name from the above page is with a unicode, i.e. the apostrophe in Wobble’s Corner is a unicode character rather than ASCII. The missing items you posted seem to be telling the issue.
Neither DIM nor dumping files manually can correctly handle the unicodes, AFAIK. The same issue ever happenend to other products before..... You should fill a support ticket.
If you want to make it work, you can try: Go to the folder data/ANSIKO/, check if the apostrope character in sub-folder name: Wobble’s Corner is as same as the one in above product name or what is shown in Missing Files. If it's not, correct it to ’. Then it should work.
I have the same Problem.
The package cannot be correctly installed if the unicodes embedded in the folders / user-facing files as well as Manifest and Metadta files are not fully fixed.
You have to either fix them yourself or wait for the fixed / updated package from Daz.
