G8 or G9 version of a dress like this?
Is there anything like this? I know There is Oriana outfit by Arryn, but it has a ruffle.
  • felisfelis Posts: 6,079
    It is a fairly easy dress to model.
    So if nobody comes with anything, I will model it next week.
  • memcneil70memcneil70 Posts: 5,543
    Have you looked at Arryn, Onnel's store? They create dresses very much like that, along with shoes and accessories. I linked to Arryn's store as both are pretty much the same.
  • IceCrMnIceCrMn Posts: 2,331
    @Felis I'm interested in this also.
    I've been looking for a dress like this for G8 myself.
  • FJM1977FJM1977 Posts: 167
    edited September 2025
    I have, and they have a couple of outfits that are close (Oriana etc.) But usually have something slightly off from what I am looking for (skirt is asymmetrical, too short/flowy/not tight, has holes, sleeves are too billowy etc.
    That would be awesome! Thank you! (if no one comes with anything, like you said, of course)
    Post edited by FJM1977 on
    Had a bit of time.
    This is what it looks like. Still need to make some additions. It is currently for G8F, but I plan to port it to G9 also. The dress is short, so I will make a morph to pull it a little further down.
    1200 x 900 - 2M
    1200 x 900 - 2M
    Post edited by felis on
    felis said:
    Had a bit of time.
    Looks good!
    Thank you @Felis
  • ElorElor Posts: 3,467
    The Renderosity archive is missing the geometry of the G8F version. When I tried to load it on G8F, I got a missing files error for these two files:
    • /data/felis/Product/G8F_Dress_28/G8F_Dress_6990.dsf
    • /data/felis/Product/G8F_Dress_28/UV Sets/felis/Base/default.dsf
    Inside '/data/felis/Product/', there is only a 'Dress_28' folder which only have Genesis 9 related morphs.
    The Genesis 9 version does load without problem.
    Post edited by Elor on
    I just posted the same on rendo.
    The G9 version does load correctly for me also.
    I am sorry.
    I realised when I packed it I made a mistake.
    I have updated the zip, and it is now back in queue for approval.
    I get an error on the page
    First it wouldn't load(it said too many redirects) then it said I had to prove I was human now it says
    "You do not have permission to view this item"
    Post edited by IceCrMn on
  • When in the Rendo re-approval queue it's invisible to everyone except the Rendo approval people. It'll return once checked.
    I am not sure what happened. I drag the updated zip in but the zip is still the old one.
  • In the past I've had to press the 'Remove' button that appears when your mouse hovers over the appropriate box. Then load in the new one.
    I don't know. When I hoover over the zip file then nothing. Have also tried to rightclick but that don't do anything either.
    That is why I just tried to drag the new file in.
    If that doesn't work, I am going to delete the current one and just recreate it.
    It's available again, just downloaded it, thanks @felis
    Yes, and I checked that both data folders were there.
    Next time before I upload I will check it on another computer. I have a laptop, it can't really run Daz Studio, but enough to verify it.
    I call this render "Early Fall".
    I changed the textures a bit.
    Thank you @Felis
    very versatile dress.
    741 x 1200 - 540K
    You're welcome.
    Very nice use.
    @Prefox has a dress like that for Genesis 9, with buttons and belt and it's a Golden Ticket today:
    https://www.daz3d.com/arietta-dress-for-genesis-9
