K.I.S.S. Band style makeup for g9 (or g8)
Is there any makeup similar to the KISS rock band's makeup for g9 (or at least g8 as I can hire someone to convert it to g9 I have an artist I hire for commissions for g9 humanoid characters textures and texture conversions) anywhere for Daz?
  • I'm particularly looking for makeup for females
  • GordigGordig Posts: 10,667
    DEM Broken Doll has a design that looks, shall we say, inspired by Gene Simmons, and would just need a white base. Paul's would be easy to do with a manually positioned star-shaped mask, and Peter's seems like it would be pretty easy to draw on in Blender or whathaveyou. That only leaves Ace's, which is probably the most complicated. Also, I don't know what era of KISS you're looking for, so I just did the original lineup.
  • What is the link to Paul's
    Paul's is just a black star on a white base. I don't have a link to it, but all you'd need to do is make/download an image of a star and apply that in LIE.
  • FSMCDesignsFSMCDesigns Posts: 12,851
    Keep in mind thast the only way a person can customize somehing for you is if they own the same product and create an option to add to it. They or you cannot share products, altered or unaltered. For instance, if a pertson creates a KISS makeup for you, it can't be on an existing texture of a product. It would have to be a LIE preset or an overlay you can then apply to the product you own.
  • felisfelis Posts: 6,117
    I would recommend using Diffuse Overlay for the Kiss textures. If you put in Base Color it might not look as expected due to translucency.
    Well yes of course . I figured that was a given fact. I guess I just used the wrong terminology. Maybe I meant LIE preset. This shows you guys I'm not an expert or professional. I know what I know and I don't know what I don't know.
