ERC Freeze Shrinks G8.1F When Applied To My Character Morph
Hello All!
So I've made myself a character in Daz Studio, fixed up some mesh issues around the eyes in Blender. I have loaded it back onto G8.1F using Morph Loader, and after the niggles around that, got the morph to load and apply.
The character is smaller than base G8.1F. I used Memorise Figure Rigging, then dialled in the morph to 100%. Then I went to the Jount Editor and did the thing where you get it aligned with the new morph's dimensions (I forget the official term just now). And then I go to ERC Freeze.
Once it's Froze, the model shrinks a further percentage. I didn't check if it reapplied the morph... but this is the problem. Why has it shrunk? Should I not dial in the morph? What am I doing wrong?
I know this gets asked a lot lol. I have had to use mobile data recently, so if I could get a direct link to a concise tutorial? Thank you.
That sounds as if you are doubling the effect - make sure that your ERC Freeze is not including any of the proeprties that are shrinking the character, if it is then you will get those both projected from the base and from the ERC linkages.
