Preparing Scene Loop
nadelveznadelvez Posts: 8
edited November 2024 in Daz Studio Discussion
I'm new to Daz3D and I'm experiencing some issues. I checked old posts but couldn't find a solution. Here's what happened: I loaded a character and made some adjustments. When I pressed the render button, it didn't render anything—just a blank image appeared. At that moment, the character's appearance changed from colored to grey in Iray. Before pressing the render button, the character was displayed in full color. When I select something other than Iray, the "Preparing Scene" loop disappears. When I close the application, it asks if I want to save. If I choose to save, it saves a blank image, which doesn't solve anything.
In short: There's no scene, nothing is loaded, but it's stuck in an infinite "Preparing Scene" loop and I can't get out of it.
Post edited by nadelvez on
  • I am not clear - is this a scene with contents or an empty scene? Is it just the one scene doing this?
  • Its starting while there's a content but afterall even if I remove content still going never ending. It continues even when there is no content, and when I want to exit the application, it asks Do you want to save it? But the scene is empty, there is nothing, even if I save it, when I open it, something empty opens.
  • If you had added content and then re,opved it the scene would be marked as chnaged. Also, adding a camera would make it count as new.
    What nVidia driver version are you using, if this is a Windows system?
  • I'm very new and a friend suggested me to change a few settings in the Surface section. I changed it and after that it went into infinite loop.
    I have RTX 4090 and 14900K windows 11 system. The game driver is installed, I will change it to studio.
  • It's not just which channel (Studio or game) but which numeric version - right-click on the Desktop>nVidia Control Panel (or, I imagine, GeForce Experience) will give that.
  • I guess: 565.90 Studio version.
    I was formatted pc and for a little time there was no error. But today I rendered a scene it took 1 hour. And then Daz3D Daz3D shut itself down. I restarted PC and opened Daz again and i was preparing scene it was fine i guess. I press render and nothing came out. there was no render. it was all empty.
    I haven't used Iray preview since I formatted the computer. I was afraid it might be caused by that. But despite this, it entered the Preparing Scene Loop again in the Iray section. There is nothing now but it still says Preparing Scene.
  • Now I saw that my graphics card has disappeared in the Iray section. Normally it was there but I guess it doesn't recognize my graphics card.
    The graphics card I use is Asus RTX 4090 OC
  • 4090 should be fine with recent vesions of Daz Studio, it may be worth trying a full uninstall/reinstall of the driver.
  • Its fine card but mine is not working very well from the day 1. I sent back and they told me its fine. In so many games its suddenly turning 1 fps for 15-20 sec. But in Daz3D its can't see my graphics card. ( Problem is this I'm sure now.) What im suppose to do If this occur.
  • Ever figure this out? I'm getting the same thing. Also, iray is not render with the gpu. I'm on Nvidia Studio Driver 581.29 with a 5090 (win11). Everything was working a couple of months ago so it's probably the drivers. :(
    To use a 50x0 card in Iray you need to render in Daz Studio 2025, Daz Studio 4 cannot support the newer cards because of the way nVidia compiled the code.
    I've just found it out the hard way with my new 16GB RTX5060Ti. Given DS2025 isn't backward compatible with 4.x plugins, I'll likely be using 4.x for any works requiring 4.x plugins, and DS2025 for the actual rendering.
