Bringing figures closer faster
in New Users
Sometimes when I load two figures, they are miles apart and height apart. Is there a command I can use in Daz Studio to bring the figures together quick instead of spending precious time dragging them back and forth, up and down?
The Align pane should work, though it's odd that they are loading offset. If the issue is that you've moved one an even simpler oiption is to select the moved figure, ctrl-c, select the new figure, ctrl-v (or cmd-c, cmd-v for Mac).
Thank you Mr. Haseltine. I think the separation is due to adding a scene to an open scene and the added scene is already posed and arranged differently. If I just add a figure then no problem.
